Activity Forums Adobe Premiere Pro Bizarre issue – render preview bar disappearing.
  • Bizarre issue – render preview bar disappearing.
    Posted by Siah Clark on July 31, 2023 at 4:23 pm
    Hi all, this is something that’s been happening for a few months now, through multiple Premiere updates. I kept hoping it would be fixed in an update, but at this point I’ve given up on that.
    The problem:
    When editing in a sequence, I will make an change to the timeline, and the yellow render preview bar will disappear. My video preview will go black. If I undo the change I just made, (usually a ripple delete between two clips or otherwise changing a clip’s position on the timeline,) the render bar will often reappear, along with my preview.
    There are a few things I’ve noticed about this issue:
    1. It seems to happen more often as I get deeper into a long edit. I work primarily on editing long webinars for clients, so I’m usually working with timelines of an hour or longer.
    2. Once the problem starts, it seems to happen exponentially more often as I proceed. Eventually, undoing my edits stops working, and I’m left without any render bar at all.
    3. Sometimes, deleting my render files will fix the issue. Other times, it makes no difference at all.
    I have tried enabling and disabling “Composite in linear color” in sequence settings, changing the codec of my video previews, using proxies (and not using proxies,) changing the resolution of my sequence, disabling Lumetri color, creating a new project, etc. Basically, I’ve done everything I can think of, and this continues to happen, even in a brand-new, clean project.
    Unfortunately, rendering the sequence ahead of time doesn’t solve the problem either. My projects usually have thousands of edits, and re-rendering just isn’t an option. Not to mention that when I have tried this, the same problem continues to happen as soon as I start making changes to the timeline.
    Again, this has happened across multiple Premiere updates. I can’t remember exactly when it started, but I believe it’s been going on for 3-4 months now. I can’t think of anything else to try. It gets very frustrating to deal with.
    Attaching screenshots with all the information I can think of that might be relevant. If you need more details, please let me know. Thanks for reading, and thanks for your help.
    — Computer Details —
    OS – Windows 10
    Processor AMD Ryzen 9 3950X 16-Core Processor 3.50 GHz
    Installed RAM 64.0 GB
    GPU RTX 3080
    Siah Clark replied 3 years, 1 month ago 3 Members · 4 Replies
  • Hector Vera
    July 31, 2023 at 7:15 pm
    Just saw the specs of your computer and it is indeed weird despite you having more than enough RAM and processing power to run these projects smoothly, it continues to give you problems. I can confirm the specs shouldn’t be the cause of the issues. Have you tried uninstalling and reinstalling premiere pro? Sometimes updates tends to mess up with some settings and I dunno why thats the case but its a theory I have. Some updates gets installed earlier than it should be and instead of fixing bugs, it creates them. So my theory would be the reinstalling of the software process. I imagine restarting the computer will not work either. Do you get any error messages when this happens? Or just glitches? Hope to hear back from you soon!
  • Siah Clark
    August 1, 2023 at 9:12 pm
    Thanks for the reply!
    I’ve tried restarting the computer, both as a method of trying to fix the issue and just in the normal course of use the last few months. Hasn’t helped.
    I’ve also tried reinstalling Premiere Pro on two occasions since this issue started, no luck.
    No error messages or anything; just the bug.
  • Ann Bens
    August 2, 2023 at 10:55 am
    Seen this too.
    I drop an AL over the timeline and the render bar will reappear.
    Then I remove the AL from the timeline.
    Could trash media cache too.
  • Siah Clark
    August 7, 2023 at 3:27 pm
    I haven’t tried the adjustment layer method you mentioned; worth a try though. Does the render bar remain even after continuing to make edits after you try this? I have also trashed media cache multiple times since this started, and it hasn’t seemed to help.
