Activity Forums Apple Final Cut Pro Legacy Bizarre glitching in FCP Part Deux
  • Bizarre glitching in FCP Part Deux
    Posted by Aaronjohnson on April 11, 2006 at 8:13 pm
    H’lo again!
    To summarize the problems I’ve been having, I’ll paste in my original post:
    I’m having some craaazy glitches in Final Cut Pro. We shot on 16mm and transferred to DVCPro NTSC. The source material has no glitching at all. When we put it on the timeline, the preview looks/plays fine. Then when we RENDER it has glitches like this during periods of motion:
    ~1 sec clip: https://prettypennyproductions.com/confidential/glitch.mov
    Isolated frame: https://prettypennyproductions.com/confidential/glitch.png
    The glitches are not just in the timeline, they are also in exported files. I’m assuming it’s some kind of setting in FCP but I can’t for the life of me figure out what it might be. I’ve checked the timeline settings vs. the source footage settings and everything seems to be matching up. Is there something I’m missing? I feel like a total n00b because it seems like it should be very simple to fix but I just can’t find any settings anywhere that will affect it!
    Before the thread died, some users suggested it might be a problem with crossed fields. I thought this might have been the problem, too, at first, but upon closer examination the lab varified that the clips should have lower dominance. Switching to upper dominance did not fix the problem. To make matters even more strange, the glitching mirrors exactly the frames that were duplicated in the original to compensate for the 24fps(film)-30i(dv) conversion. Lab can’t figure this out, neither can I, neither can three local editors I’ve consulted…
    What is going on?!
    Thanks in advance for your advice!
    Aaronjohnson replied 20 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Aaron Neitz
    April 11, 2006 at 9:06 pm
    What are version numbers: FCP? QT? Are you using hardware like Aja or Blackmagic?
    I’ve had glitchy renders, but I’ve never seen this.
  • Aaron Neitz
    April 11, 2006 at 9:12 pm
    …wait, when you say you have to “render” the footage – do you have effects? That is, when it’s on the timeline are you getting a green preview line or anything?
  • Aaronjohnson
    April 12, 2006 at 1:53 am
    I’m not at the client’s office right now so I can’t check out the FCP version, but I think it’s the latest version. Same with QT. There are no filters or effect… The glitching occurs when dragging the video straight onto the timeline. I’ve compared the properties of the timeline to the properties of the video and EVERYTHING matches up. ENIGMA!
  • Todd Beabout
    April 12, 2006 at 8:03 pm
    Just wanting to clarify… In your original post you said:
    “When we put it on the timeline, the preview looks/plays fine. Then when we RENDER it has glitches like this during periods of motion”
    But in this post you then say:
    [AaronJohnson] “There are no filters or effect… The glitching occurs when dragging the video straight onto the timeline.”
    This sounds contradictory. Are you sure there is not some specific filter that you might have applied? Because if your sequence and source clip settings all match you should not have to render obviously.
    When you get back to the FCP box, also check to see what you are using to capture (i.e. AJA, Blackmagic, etc.) like Charlie asked. This could help troubleshoot the problem. Also, and just asking here… you didn’t try to add another pulldown or anything like that did you?
    -Todd Beabout
    Vazda Studios
  • Aaronjohnson
    April 13, 2006 at 12:32 am
    Hey, thanks for everything thus far…
    I’m positive there are no filters or effects. When I say it looks fine before we render, I mean, it looks fine in draft mode. It does have a red bar, however, exactly like it would if there were a filter or effect – but I assure you, we haven’t applied any filter or effects! I messed with pulldown to see if it had anything to do with it and it doesn’t seem to help, but to answer your question – no, no pulldown.
    So essentially, in short… When you lay it down in the timeline, it looks fine, but it’s in draft mode and there is a red bar. When you render it, it takes an unusually long amount of time and then the glitching occurs. So, it would seem to me like there is some sort of conversion/filtering going on but I can’t for the life of me figure out where it’s happening. One odd thing… The source video says it’s 486×720 instead of the usual 480×720, but it also says it’s regular ol’ NTSC DVCPRO/25. I have a feeling this might have something to do with it, but i can’t seem to change the timeline to 486×720 for love nor money and I don’t even know if that would help.
    Gasp.
    -Aaron
  • Dan Nocera
    April 13, 2006 at 6:35 pm
    Did the transfer house give you the the transfered footage dv on tapes or did you get it on a hard drive as quicktime files?
    DV footage should always be 720X480. You said it was listed in a browser as 720X486 which is the size for CCIR 601 uncompressed video.
    It sounds like it was captured wrong with the wrong preset.
    If that was the case just throw out and recapture using DV NTSC preset
    It’s also why you have to render everytime you pull it into a dv sequence.
    Try opening one of the clips in quicktim and get info and then get properties and see what it says.
    What is the frame rate listed as?
    See what it says especially under format.
    If it says DV/DVCPRO – NTSC, 720 x 480, Millions under format
    and 29.97 for FPS
    and 720X486 pixels under normal size (wrong size)
    Try going into properties ->video track->visual settings and uncheck preserve aspect box and change scale size to 720X480
    then save a self contained copy of the footage, import new footage and see if that fixes the glitching problem
    Dan Nocera
    CTFCPUG Moderator
    If all else fails give it a whack!!
    -Anonymous Techie
  • Aaronjohnson
    April 13, 2006 at 7:22 pm
    I’ll check all of that out tonight when I go to the client’s office again. For what it’s worth, we never captured anything – it was given to us on a hard drive.
