Activity Forums Adobe After Effects Bizarre display
  • Bizarre display
    Posted by Warren Morningstar on December 15, 2010 at 7:50 pm
    I have an AE project created by another artist. The moment I scrub the CTI, the graphic repeats on the screen in false colors and black and white. Any idea what’s going on and how to fix?
    Running CS5 Windows 7 64 bit Intel i7 CPU 965@3.20GHz NVIDIA GeForce GTX470
    Spaceman —> replied 15 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tudor “ted” jelescu
    December 16, 2010 at 10:14 am
    Most likely is a matter of codecs- you are probably missing the codecs the original artist used to render out some of the files he was using.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
  • Spaceman —>
    December 16, 2010 at 11:00 am
    SPACEMAN had a very similar problem recently, which was only fixed by replacing the graphics card. SPACEMAN was working too much and the graphics card was not.
    SPACEMAN needs spaceship parts, not expressions…
  • Warren Morningstar
    December 16, 2010 at 1:07 pm
    I don’t think this is a codec issue. This isn’t the result of a render. It’s what I see on the monitor the moment I scrub on the timeline. I’m thinking this is a hardware or settings thing, but I don’t know where to begin looking.
  • Michael Szalapski
    December 16, 2010 at 2:39 pm
    It’s possibly a codec issue depending on what version of AE you’re using and what codec the footage you’re using is encoded in, but I would also suspect OpenGL. Turn off OpenGL for previews AND for rendering and see if the issue goes away.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
    December 16, 2010 at 4:06 pm
    Thanks for the suggestion, but it’s not Open GL. Turned it off and the problem still appears.
    However, tried importing the comp into a new project by following the steps outlined in this post https://forums.creativecow.net/thread/2/930926 and that seems to have solved the problem.
  • Michael Szalapski
    December 16, 2010 at 4:52 pm
    “SPACEMAN had a very similar problem recently, which was only fixed by replacing the graphics card. SPACEMAN was working too much and the graphics card was not.”
    I’ve missed seeing you around, SPACEMAN. Nice to see you around again 🙂
    – The Great Szalam
  • Spaceman —>
    December 16, 2010 at 5:10 pm
    SPACEMAN has spent the last few years with cameras, lights, computers, humans and “other toys” [classified] and was missing the COW a lot.
    SPACEMAN is very happy to be back again.
    SPACEMAN will try to be useful.
    SPACEMAN thanks The Great Szalam for his kind words.
