Activity Forums DVD Authoring Bitvice won’t compress
  • Bitvice won’t compress
    Posted by Christopher Pearson on September 2, 2007 at 7:08 pm
    I create all my MPEG-2’s using Bitvice 1.6 and never had a problem until now. I’ve got a Quicktime movie that is giving me trouble. I get an error from Bitvice stating, “Unable to create file for output MPEG-2 movie”.
    The QT originated from DV, but I no idea how it was captured to QT (The file is Component Y’CbCr). The QT Movie Inspector tells me the file format is this:
    Photo Sharing and Video Hosting at Photobucket
    In attempt to convert the clip to something usable, I’ve tried exporting it from FinalCut as a normal DV NTSC 720X480 and Bitvice still wouldn’t compress it.
    Any ideas would be GREATLY appreciated.
    Thanks in advance…
    Roger Andersson replied 19 years ago 2 Members · 1 Reply
  • Roger Andersson
    September 9, 2007 at 4:22 pm
    This happens when BitVice for some reason is not allowed, by the OS, to create a new .m2v file in the folder you selected. Check that your user has write permissions for the folder.
    Since BitVice is denied to open a new file, there is no point in starting an encoding session, because there is no way to save the result.
    Roger Andersson / Innobits AB Sweden
