Activity › Forums › VEGAS Pro › Bitrate vs. Compression
  • Edward Troxel
    February 7, 2006 at 6:58 pm
    They are both directly related. To fit on a DVD, you must COMPRESS the file. However, the question becomes… HOW MUCH will you compress the file? The bitrate determines that. The higher the bitrate, the bigger the file, the lower the compression. The lower the bitrate, the smaller the file, the higher the compression.
    Edward Troxel
    JETDV Scripts
  • Javaholic_ir1
    February 7, 2006 at 7:55 pm
    Do I understand that some applications encode via variable bitrate and other’s use a fixed predetermined bitrate based on video size? Can anyone tell me how Sony handles their ‘Fit-to-Disk’ application used within DVD Architect Studio 3.0…variable or fixed or other?
    Thanks…
    http://www.javaholics.net
  • Edward Troxel
    February 7, 2006 at 8:19 pm
    My understanding is that DVDA using single pass VBR (Variable BitRate). I could be wrong.
    Edward Troxel
    JETDV Scripts
