Activity Forums VEGAS Pro Bitrate settings
  • Bitrate settings
    Posted by Mark Nacovitch on November 4, 2011 at 5:08 pm
    Going from a DV to create a DVD, I am confused about setting the constant bitrate settings.I use a calculator for the settings.I use the Dolby Digital AC-3 Pro setting for the audio. The calculator has choices for audio ranging from 32kb/s-1536kb’s PCM audio.What setting on the calculator should I use?The difference in settings seems to be a lot-depending on your audio.
    Thanks, Mark
    Mike Kujbida replied 14 years, 10 months ago 3 Members · 4 Replies
  • Mike Kujbida
    November 4, 2011 at 5:56 pm
    The AC-3 default in Vegas is 192 kb/s.
  • Mark Nacovitch
    November 4, 2011 at 6:07 pm
    Thanks Mike. One more question. I had always thought that the bitrate should be between 6.5-8.5. This puts mine at around 9.3. I am going from DV camcorder to DVD-sports video’s that usually last an hour. Does this seem like the correct setting to you?
  • Ted Snow
    November 5, 2011 at 6:46 am
    My calculator shows a CBR of 9576 for one hour of DVD using Dolby 2.0 audio with no menu.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
    VEGAS 8.0
    VEGAS 11.0 32 & 64 bit
    Sony VX2100
    Sony HVR-Z7U
    Alesis HD24
  • Mike Kujbida
    November 5, 2011 at 11:09 am
    Mark, my rule of thumb is that for anything less than 70 min., I use a CBR of 8,000,000.
    Most folks will bump that up to 8,500,000 but that’s as high as I’d go to ensure maximum compatibility.
