Activity Forums Adobe Premiere Pro Bitrate setting for YouTube export
  • Bitrate setting for YouTube export
    Posted by Joey Williams on May 30, 2013 at 2:57 pm
    I’ve shot some video on my Canon C100, and I’m trying to find the best bitrate/export recipe for YouTube. I’m exporting MP4/H.264/1080p.
    I’ve read around, and there are a variety of answers, but would like to hear what is working for other for the best possible quality for YouTube. I’ve set my max bitrate at 20M, and average at 15M.
    Anyone have settings that work well for them?
    JW
    TOAD ARRAY
    https://toadarray.com
    Kris Merkel replied 13 years, 3 months ago 4 Members · 3 Replies
  • Ryan Holmes
    May 30, 2013 at 3:46 pm
    What you have sounds about right. If it’s a short clip (i.e. less than 10 minutes) you’ll be fine. If it’s an 1-2 hour presentation then you’ll have to have a pretty fast internet connection to push the finished file up to YouTube. You’re always fighting size vs. quality with internet compression.
    I always point people to Vimeo’s compression guide. It’s got a good walkthrough of the different compression settings and generally accepted good starting points for data rate and resolutions.
    https://vimeo.com/help/compression
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Ann Bens
    May 30, 2013 at 4:51 pm
    Use a YouTube preset (under H.264) they work just grand.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Kris Merkel
    May 30, 2013 at 5:50 pm
    Both Ryan and Ann are spot on. Something else to consider as well is using CBR for shorter duration programs and also experimenting with the bit rate settings to optimize your file size and maintain a good balance between encoding time and quality.
    Just because you can encode at 20Mbps doesn’t mean that you should or even need to.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
