Activity Forums DVD Authoring Bitrate Questions
  • Bitrate Questions
    Posted by Steven Free on April 12, 2006 at 2:39 am
    Hello,
    I’m all finished with 2 different video projects in Premiere 6.5 and ready to export them both from Premiere using the “Adobe MPEG Encoder” and bring them into a DVD authoring program called “DVD Lab Studio” by Mediachance. I will be burning a master of each to have DVD replications made down the road.
    My question is how do I know what my audio bitrate should be set to https://www.videohelp.com/calc.htm so I can have a Calculated Bitrate?
    Also, what is the difference between “Calculated Bitrate” and “DVD Max Bitrate” on that site?
    Thank you
    Steven Free replied 20 years, 5 months ago 3 Members · 3 Replies
  • Noah Kadner
    April 12, 2006 at 3:28 am
    If you are using VBR, you set avg to calculated and max to max. For Ac3, typically 192Kbps is fine for stereo.
    Noah
  • George Wing
    April 12, 2006 at 11:29 am
    In that calculator you referenced, the item labeled “DVD Max Bitrate” is just a reference for how large your MAX video bitrate can be based on the dvd spec limit of 9800kbps (video+audio — 10080kbps adding in subpics). Notice how it changes when you adjust the audio bitrate (it leaves a little room for menus and overhead). But I wouldn’t necessarily use it for VBR MAX because you might be setting the video bitrate up to 9600kbps (and some encoders will periodically “spike” above your stated max number — potentially making your dvd non compliant).
    Also, if you plan to have a second audio track, make sure you change the number of audio tracks using the “Advanced” mode of that calculator.
    Regards,
    George
  • Steven Free
    April 13, 2006 at 8:34 pm
    I’ll give it a try. Thanks!
