Activity Forums Apple Final Cut Pro Legacy Bitrate drops
  • Posted by Mohannad Mahmoud on November 9, 2012 at 2:28 pm
    Hello Everyone,
    I am facing an issue when exporting into a quicktime file. Everything worked well in the past months, but now when I export into a quick time file using the same settings I used, which are, MPEG-4 codec and bitrate 8400kbps and taking the quality highest, the final video turns out to 5000kbps. I also tried to export via Compressor, but the same result; the bitrate drops
    Any ideas on that guys?
    Appreciate it
    Rafael Amador replied 13 years, 10 months ago 2 Members · 3 Replies
  • Rafael Amador
    November 9, 2012 at 4:40 pm
    If you are making a multipass and Key-frames . AUTO, that’s normal and is OK.
    Do the picture looks bad?
    rafael
    http://www.nagavideo.com
  • Mohannad Mahmoud
    November 9, 2012 at 4:56 pm
    Thanks for Rafael,
    Yes the pic quality dropped and I am required to have it in a certain kbps. I tried in another codec, it did not drop the bitrate, the final outcome was as I set the bitrate to be.
    Do you know if there is any option that has created a limit on the mpeg4 codec?
    thanks again
  • Rafael Amador
    November 10, 2012 at 12:47 am
    You can make the MP4 containing H264, which will yield better quality.
    – Go to the top of the window (Video tab) and select File Format > MP4 (No ISMA).
    – In Video Format. select H264.
    – Set the data rate you wan’t and Current size (if you don’t want rescaling)
    – Set Key-frames > Automatic
    – Click Video Options and select Main profile and Multi-pass.
    rafael
