Activity Forums Apple Final Cut Pro Legacy bitrate calculator wmv v9
  • bitrate calculator wmv v9
    Posted by Maurik De ridder on October 10, 2006 at 9:26 am
    hello there…
    i recently installed flip4mac to export from fcp wmv’s version 9
    anyway i would like to be able to calculate infront the bitrate so i can specify
    how big the file was in fcp and the desired file in wmv ….
    for instance :
    moviefile is 5 Gb, duration 120 seconds, 720x 576, used codec wmv v9, two pass vbr and the desired file has to be 640×480, and = 20 Mb
    you enter this in the calculator and the calculator says the bitrate has to be 300 bps
    does anyone know such a calculator (using apple btw)
    thanks Maurik
    Maurik De ridder replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
