Activity › Forums › VEGAS Pro › Bitrate calculator didn’t work :( DVD not fitting.
  • Mike Kujbida
    May 25, 2011 at 9:57 am
    DVDA has a long history of incorrectly reporting file sizes.
    With the settings you used, there’s no reason why it shouldn’t fit.
    Ignore the warnings and my guess is that it will proceed without any further grief to you.
  • Nigel O’neill
    May 25, 2011 at 10:25 am
    Benjamin
    You might want to check your DVDA template audio settings. If it defaults to PCM, it will want to rerender the audio and create DVD files that exceed the disk size. I set my DVDA audio to AC3.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • David Shirey
    May 26, 2011 at 8:17 pm
    [Mike Kujbida] “DVDA has a long history of incorrectly reporting file sizes.
    Ignore the warnings and my guess is that it will proceed without any further grief to you.”
    A thousand times this. Just yesterday I had to cram 2.5 hours on a single-layer DVD-R (It’s okay it was just a timecode window burn) and DVDA said it would take up 5.3GB I think. It burned onto a 4.7 just fine. DVDA is a liar, ignore it.
