  • BITC in fcp
  • dan crouch
    March 12, 2011 at 9:46 am
    Very simple question…
    Can fcp generate BITC.
    I need to burn a dvd on my mac and can’t find out if I can
    make it with BITC.
    Thanks in advance.
    Dan.
  • Rafael Amador
    March 12, 2011 at 10:39 am
    There are two filters that will burn TC on the picture:
    – TC reader; Will read the original TC of the clips on the sequence.
    – TC Generator: Will generate a TC starting with the default 00;00;00;00 or the TC that you set.
    If your time line has cuts and you want a continuous TC, nest the sequence and apply the TC Generator.
    rafael
    http://www.nagavideo.com
  • dan crouch
    March 12, 2011 at 10:41 am
    Awesome! thanks v much.
    Dan.
Viewing 1 - 3 of 3 posts
Log in to reply.
