Activity › Forums › Apple Final Cut Pro Legacy › Bit Rate
Bit Rate
Posted by Jeff Lazzarino on May 25, 2005 at 10:37 pmCan anyone tell mehow to slow down the bit rate when exporting from FP using Compressor.
Pdr replied 21 years, 4 months ago 2 Members · 3 Replies -
Pdr
May 25, 2005 at 10:56 pmHi Jeff
You will need to make a copy of the existing Compressor preset as follows:
1. Select the MPEG2 Preset you wish to base your new Preset on
2. Click the Encoder tab
3. Click the Quality tab
4. Make changes to Average Bit Rate and Maximum Bit Rate as required
5. Click back on the Presets list
6. A dialog sheet will prompt you to save the setting: Make sure you Save as copy, and give it a meaningful name
7. Your new Preset will appear in the bottom of your Prests listHope this helps.
Regards
Peter—
Peter Dominic Ryan – Freelance Editor
raycity* media – pdr@raycity.comPowerMac G5 Dual 2.0 GHz, 4GB, Mac OS X 10.4
FCP HD 4.5, Motion 1.01, DVD SP 4 -
Pdr
May 26, 2005 at 12:46 amHi Jeff
Sure it’s okay, but the lower the bit rate, the lower the quality of the encoding.
Regards
Peter—
