Activity Forums VEGAS Pro bit rate too low
  • bit rate too low
    Posted by Glenn Rotar on December 31, 2012 at 8:32 am
    I have followed this procedure before. In Vegas select dvd NTSC WIDESCREEN. Next bring in and edit my videos. Next selext projects, then “render as”, then render sound, next render video as “dvd architect ntsc widescreen”. repeat this with other projects.
    THEN I go into DVD Architect import them in and make a dvd. I’ve done this 6 or so times but this time I have 7 red errors saying the same thing. “video cannot be recompressed because its bit rate is too low” The intro video has been used in 3 other disks I have made but this time it has this error. I appreciate any help but please keep it simple for me. Thanks
    Glenn Rotar replied 13 years, 8 months ago 3 Members · 3 Replies
  • Mark Krueger
    December 31, 2012 at 11:51 am
    Bit Rate too Low to make DVD
    Open DVD Architect while holding down the Control and Shift keys together.
    It will then ask you to delete cached items. Check the box and say yes.
    That should return the settings to default and everything should work.
  • Roger Bansemer
    December 31, 2012 at 2:00 pm
    You can also save a step by doing a batch render so you don’t have to go back and render the audio and video separately. I’ve added a icon via the “customize toolbar” so I can select whatever options I want and begin to render a number of different options.
    Roger Bansemer
  • Glenn Rotar
    December 31, 2012 at 5:09 pm
    Thanks – I tried it and I have couple questions. If I reload my project the problem is still there. Do I need to redue the reloading and menu creation all over or is there a step that is simpler?
    2nd Question is re. understanding this. How do I prevent this and why does this need to be done? thanks again
