Activity Forums Creative Community Conversations Bit rate confusion in mid flight
  • Bit rate confusion in mid flight
    Posted by Donn Lawler on June 19, 2012 at 3:14 pm
    Hi gang!
    So I ingested some footage for a friend to make DVDs of her Hi8 videos… The total time was around 5.5 hours so to get it all on DVD, I broke them up into five 1 hour projects in FCP X , then simply burned the projects to disc using the share option and the DVD set up… The first 2 burned fine, the third stalled out and gave me the message that the bit rate was too high… I attempted to successfully burn the fourth and fifth projects as well so it’s just hanging up on the third project… And I can’t for the life of me figure out why, as it was all captured at the same time using the same camera and the same settings! I must be looking at the problem form the wrong angle and wanted to share this along with a plea for help and suggestions as to why, for all intents and purposes, a series of clips in a project would not render to disc… Especially since said project came from the same captured media… Thanks in advance for any input! I really appreciate it.
    Donn Lawler replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
