Activity Forums Adobe Premiere Pro Bit Depth & Transcoding
  • Bit Depth & Transcoding
    Posted by Eric Klassen on December 9, 2014 at 12:34 am
    I’ve set up a test for a client that involves testing individual clips, comparing 8bit vs 10bit quality. I’m using Premiere CC to set up a timeline with a single clip and encoding out of Premiere using: H.264 and customizing the Bitrate settings to Target=8 Max=8 for the 8bit version of the clip. Then repeating with 10bit in the settings, getting two MP4s, one with 8bit & and one with 10bit quality.
    As a secondary test, I’m also exporting out of Premiere a 4K UHD Mezzanine of the clip, using ProRes422, and putting it through an Elemental transcoder to 1920×1080. I’ve checked all the settings and I’m almost positive it’s all the same. The Elemental transcoded MP4 looks way better than the MP4s out of Premiere: less banding which is what the test is supposed to show.
    Can someone explain this?
    Eric
    Eric Klassen
    Angelo Lorenzo replied 11 years, 9 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    December 9, 2014 at 11:26 pm
    Apples to oranges – Premiere uses Apple’s native (MOV, TERRIBLE quality) or MainConcepts(MP4, decent quality/speed) while Elemental uses in-house developed codecs (my bet is a fork of x264). There are a lot of variables that can be fine tuned in terms of quality over speed which makes comparing 8bit and 10bit a little bit muddy.
    You may find x264 through the use of the command line app FFMPEG to be of better quality than MainConcepts if you want something to deploy to your client on the cheap. If you’re on Windows then XMedia Recode is an excellent front end (site is in german, app is in english) that will expose you to a lot of those fine tune settings so you don’t have to go through pages of command line options.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
