Activity Forums AJA Video Systems bit depth query
  • bit depth query
    Posted by Justin Heaney on April 4, 2005 at 3:57 am
    Hi All.
    Can anyone explain how 8 & 10 bit cards like Kona & AJA I/O handle 8, 16, & 32 bit float point renders from combustion or after effects.
    How do these render depths relate to the display depths in these cards, and can I view a 32 bit float point render via one of these cards. (e.g TIFF float point)
    Or does the card (i.e an 8 or 10 bit card) down-res the float point render??
    Justin Heaney
    Justin Heaney replied 21 years, 5 months ago 3 Members · 4 Replies
  • Adam Schmidt
    April 4, 2005 at 10:56 pm
    Although FCP can work and render float type data via a setting in the video setup dialogue box, it will only work as a functional editor with data well suited to video playback. I was shocked when FCP opened and played avi and mpg files, but I can not edit with them in an efficient manor. in out cards can work in 8, 10, and 12 bit resolutions, but the video needs to be in a codec that FCP will function with. On the io, apple and aja support the Apple UC 10bit codec. This is a true 1024 color per channel codec without alpha in a 4:2:2:0 YUV arrangement. The io also supports the black magic codecs in both 8 and 10 bit depths. The kona 2 cards can work with 12 bit video (4096 colors per channel) via there own 12bit codecs. All of this can be rendered and processed in a float setup with most filters and codecs, but FCP will only run well when the quicktime based codec meshes well with the hardware that supports it.
    FCP nor QT supports natively “frame stack” data like what you describe. Instead, use a QT codec that supports 10-12bits and turn on float in the settings. Then any work that you do in FCP will be processed in a float environment, but in the codec transition you will loose the “cary over” or “greater than” information in the original file. Float based rendering will greatly slow down FCP’s operation. FCP 5 will have a full “shake 3” like implementation of float FPU based information.
    Adam
  • Justin Heaney
    April 5, 2005 at 9:04 pm
    Cheeers Adam.
    That helps me heaps to understand how the bit depths work. I use combustion alot and have settled on Blackmagic 10bit.
    You wrote
    “FCP can work and render float type data via a setting in the video setup dialogue”
    Which setting is this, and where do i find it?.
    I also wonder if the Kona 12bit codec, can be made available on the AJA I/O. What do you think?
    Thanks again
    Justin Heaney
  • Ajschmidt01
    April 6, 2005 at 7:54 am
    Hey, this is adam, cow removed my account over a rumor i posted in the fcp forum.
    Under sequence settings: video processing: high-precision yuv.
    No the io can only use 10bit or less. You can use the BM 10bit if you need to move between the mac and pc, or a mac without the apple 10bit.
    Adam
  • Justin Heaney
    April 6, 2005 at 9:07 pm
    Cheers for that.
    I was getting lost looking for a 32 float setting.
    What’s this rumour you speak of?
    Justin
    justin1@gmail.com
