Activity Forums Adobe Encore DVD bit budgeting
  • bit budgeting
    Posted by David on January 10, 2006 at 10:44 pm
    Howdy all,
    So I’m working out my bit budgeting for a DVD I’m putting together by following the examples given in the Encore help files.
    It says there that in order to determine the maximum video data rate, I need to subtract the combined audio data rates (0.192 Mbps x 22 audio files, in this case, which = 4.224) from the maximum DVD video data rate (9.8 Mbps), which comes out to 5.576 Mbps. Is this correct? That is, do I need to multiply the audio data rate times the number of audio tracks there are in my project?
    I only ask because I have come to a calculation of a data rate for my video (34,837.888 Mbits available / 4,920 seconds of video = 7.08 Mbps) that is apparently greater than the maximum video data rate for my disc (5.576 Mbps). Should this be possible? If so, do I just set the data rate for my video to 5.576? Have I miscalculated something? Any help you could give me with this problem would be much obliged. Thanks!
    – David
    Dominic Osborne replied 20 years, 8 months ago 3 Members · 2 Replies
  • Matt Dubber
    January 11, 2006 at 12:02 am
    Bid budgeting is confusing. You don’t need to calculate 0.192 by the number of audio files in your project….just by the number of audio TRACKS you have per timeline. I assume you only have one audio track in each timeline. Audio and video bitrates together can be no more than 9.8Mbps.
    The way I calculate a bitrate is as follows.
    36096 Mbits / 4920 seconds = 7.3Mbps – 1 audio track (0.192) = 7.1 Mbps.
    So 7.1Mbps total bitstream will fill your disc with your 82 minute program that cpntains one video track and one audio track per timeline.
    This is the calculation I use all the time and it comes very close (because the video bitrate I use is a variable bitrate)
  • Dominic Osborne
    January 12, 2006 at 5:55 pm
    i put a bitrate calculator together for our company (www.eighteyedseabass.com) in Excel if that’s of any help?
