Activity Forums Adobe Encore DVD bit budget individual assets?
  • bit budget individual assets?
    Posted by Peter Malof on November 27, 2006 at 5:31 am
    I’ve wound up with over 180 minutes on my disk. Amazingly it doesn’t look bad until fast motion segments play, and they look pixelated. Most of the 180 minutes are archival pieces that don’t need to be high quality. I have two short pieces I want to look really good (an 18 minute piece and a 23 minutes piece). Is it possible to set these two pieces to 7 or so and let Encore adjust the other pieces downward accordingly? I’ve tried right-clicking on individual assets, but the transcoding options are grayed out and not available. Peter
    Peter Malof replied 19 years, 10 months ago 2 Members · 2 Replies
  • Jeff Bellune
    November 27, 2006 at 12:17 pm
    Do a Revert-to-Original on the shorter assets and then set the transcoding bit rate for them.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Peter Malof
    November 27, 2006 at 2:58 pm
    Thanks Jeff — the “revert to original” was the ticket. Then it seems I had to assign a low custom transcode setting for the whole project, then go back and set the three individual assets for which I needed higher bitrates manually. With the lesser assets set to transcode automatically I was able to keep raising the bitrates on the important assets until I was happy with the mix (and until “check project” didn’t show an error that the project was too big for the disk). It’s building the disk now–hopefully my pixelation problem will be solved. Peter
