Activity › Forums › VEGAS Pro › Binding the Automation Parameters
  • Binding the Automation Parameters
    Posted by John Perez on June 30, 2019 at 8:04 pm
    I’ve added a Simple Delay Audio Effect to an audio track and I want to use several parameters of it, each of which lays in a separate “Envelope Line” but it’s like handling several very thin threads on the timeline; super tedious. How can I “bind” these “threads” (the parameters) together so I can adjust the bunch as a single envelope line? Thank You
    HP Intel(R) Core i-7 CPU
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
    As always thanks so much to you guys…Johnny In Orlando
    Graham Bernard replied 7 years, 3 months ago 2 Members · 2 Replies
  • Graham Bernard
    July 1, 2019 at 4:55 am
    [John Perez] “How can I “bind” these “threads” (the parameters) together so I can adjust the bunch as a single envelope line?”
    Hi John! I’m kinda out of my comfort zone here, but having been experimenting lately using BUS Tracks, could you create a SFX BUS TRACK “A”, with ALL your Envelopes in that and then connect your Audio Track to that? I know I have done this recently using my PreSonus FaderEight Control Surface. I end up with the SFX BUS A, or B or ….. E. I know that this works and I can adjust those complex Envelopes and then listen in real time as I adjust the Faders in, say, SFX BUS E. That’s really cool ????.
    * Grazie
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Graham Bernard
    July 1, 2019 at 5:43 am
    [Graham Bernard] “I know I have done this recently using my PreSonus FaderEight Control Surface. I end up with the SFX BUS A, or B or ….. E.”
    OK, doing this without my First Coffee of the day, and this does work:
    So I have Multiple Automation/Envelopes applied in BUS “A”, which I CAN Adjust in BUS “A” and then have that Plane4 Track have BUS “A” applied to it! Tah-dah! ????
    * Grazie
