Activity Forums Apple Final Cut Pro Legacy Bin settings
  • Posted by Ron Craig on May 6, 2008 at 5:05 pm
    I know I should know this — or at least be able to find it in the manuals. But I can’t. And a search here turned up nothing (probably because I couldn’t figure out the right search terms.)
    Anyway, I don’t know how to establish bin default settings in FCP. I’d like the columns in the bins to display in my preferred order and I know they can and I know I probably knew how to do this at one point and yes it’s really elementary, etc. So that’s why I’m posting in the Basics forum. BTW, I’m on FCP 6.
    Jenna Bliss replied 15 years, 9 months ago 3 Members · 3 Replies
  • Tom Meegan
    May 6, 2008 at 8:28 pm
    From the manual page 71.
    Saving and Using Custom Column Layouts
    You can create customized column layouts and save them for easy access at any time.
    To save a custom column layout:
    1 Rearrange the Browser columns the way you want them to appear.
    Note: The Name column always appears on the far left and cannot be moved.
    2 Control-click any column heading, then choose Save Column Layout from the
    shortcut menu.
    3 In the Save dialog, choose where you want to save the layout, change its name if you like, then click Save.
    Custom column layout files are saved by default to the following folder location:
    /Users/username/Library/Preferences/Final Cut Pro User Data/Column Layouts/
    To open a custom column layout:
    Control-click any column heading in the Browser except Name, then choose a custom layout from the shortcut menu.
    If you have placed column layouts in a location other than the default folder mentioned above, you will need to open them using the Load Column Layout command in the shortcut menu.
    To open a custom column layout that is not in the default location:
    1 Control-click any column heading in the Browser except Name, then choose Load Column Layout from the shortcut menu.
    2 In the Choose a File dialog, navigate to the location where the column layout is stored, select it, then click Choose.
    Tip: You can also save and use custom column layouts in the Find Results window, following the same instructions you use for the Browser. Any custom column layouts created in the Browser can be used in the Find Results window, and vice versa.
  • Ron Craig
    May 6, 2008 at 10:20 pm
    Well, that was a complete answer. Thanks!
  • Jenna Bliss
    December 14, 2010 at 3:24 pm
    In Addition, can you change the name of the columns in a FCP bin?
    I know you can in Avid…
    Jenna D Bliss
