Activity Forums Avid Media Composer BIN ERROR….HELP!
  • BIN ERROR….HELP!
    Posted by Scott Sawala on April 24, 2005 at 3:26 pm
    Hi there-
    I am having major issues. I’m using AVID Symphony 4.5.1 Win2K 2.8GHz Compaq 1.5GB RAM. I can’t open my bin. I get ACCESS_VIOLATION exception occurred….Then in the more info I get DISC_COPYOUT_FAILED. I tried to load the last saved attic file and that won’t open as well. The previous version in the attic is from more than a month ago?? The bin is set to auto save every 15 min. with 30 versions?? I don’t get it. I tried sending the bin to someone else to see if they could open it, and they couldn’t. They tried sucking it in to media manager and it would’t see the file. I just need my sequence that’s in this bin…everything else can go. Can I just suck out the sequence somehow. By the way, the bin is 20MB which I understand is a large bin. I think it is because it’s a 90 min. program with a ton of effects. Any help would be greatly appreciated.
    Scott
    Scott Sawala replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
