Activity Forums Apple Final Cut Pro Legacy Bin Editing:
  • Posted by Gray Morison on November 8, 2010 at 6:05 pm
    I was wondering if there is a way to add the contents of a time line to a bin in order. I have several hours worth of tiny clips for a documentary and I have them in chronological order. I would like to drag them into my bin so I can rearrange them a little bit, but every time I try they randomize in the bin.
    Jack Bibbo replied 15 years, 6 months ago 2 Members · 1 Reply
  • Jack Bibbo
    November 10, 2010 at 12:08 am
    You may be getting this because when you bring them over you have the column “name” select or ANY column with info selected. This may be causes them to then sort by that order.
    If you create a column with NO INFO in it than drag the clips over to the empty bin they may keep their seq order.
    just one thought.
