Activity Forums Media 100 Bin clip doesn’t match media played
  • Bin clip doesn’t match media played
    Posted by Rob Duncan on May 21, 2007 at 10:55 pm
    When I look at the bin, I see all my (seemingly correct) video thumbnails, and see also that the media is listed as present.
    When I play it, I get a completely different video track, with the correct audio track underneath.
    If I select ‘show media in finder’, I am presented with a media clip that is orphaned (ie. no supporting audio clip, though the clip does play sound in the edit suite).
    Now, I looked at a source file nearby that was next to in in timecode (guessing by the naming convention of the media), and lo and behold, it’s my clip.
    First – any thoughts as to what is causing these bin ghosts?
    Second – is there any easy way to relink bin and media? Earlier, this same haunted bin though that 4 video clips went offline (they are connected directly to the computer via FW800), and then after a brief panic, they came back on their own.
    I’d appreciate any insight. Perhaps I just need to give myself and the software and well-earned break.
    Rob.
    David Colantuoni replied 19 years, 4 months ago 2 Members · 1 Reply
  • David Colantuoni
    May 22, 2007 at 3:12 pm
    Check your drive creation dates. If you have 2 drives that are created at the very exact time as each other (say-if you create an array of multiple partitions) this could cause this problem.
