Activity › Forums › Apple Final Cut Pro Legacy › BIG TROUBLE WHEN CAPTURING
Posted by Sergio Deustua on May 19, 2006 at 2:36 pmHI.
I have tremendous trouble when I whan to capture video from my AJHD1200A deck, just canSergio Deustua replied 20 years, 4 months ago 2 Members · 8 Replies -
Matthew Brunn
May 19, 2006 at 3:16 pmPossibility is a bad Firewire cable.
Try digitizing in another user. Just create one for the test and try to capture a few seconds. If it works you know that the user prefs are corrupt. If it still crashes try…
If this is the case then go into Mac HD>Users>Your user>Library> and take the entire preference folder out to the desktop. Then I restart FCP and see if it crashes. I add back some of the old prefs into the newly created Pref folder and restart FCP. Repeat until FCP crashes and you found your corrupt Pref file.
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
FCP 5.1/AE 6.5/DVDSP4 -
Sergio Deustua
May 19, 2006 at 3:30 pmThanks Matthew
I moved the entire pref folder to the desktop, restart fcp and it still crashes. So, it didnt work out.
Do you know what else can I do. -
Matthew Brunn
May 19, 2006 at 3:43 pmWell it starting to sound like a hardware trouble. Do you have another suite to take the deck to for testing?
Did you try another firewire cable?
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
Sergio Deustua
May 19, 2006 at 4:40 pmI tried another firewire cable and also tried it in another computer.
o you think it could be a hardware trouble? -
Matthew Brunn
May 19, 2006 at 8:13 pmIf you tried another computer and the you get the same I would blame the deck.
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
Matthew Brunn
May 22, 2006 at 1:10 pmThat is possible about the OSX but others have that deck and are not experiencing the same issues. Just a good idea to have the deck checked out because you with no options as is.
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
