Activity › Forums › Apple Final Cut Pro Legacy › Big render times….really confused???
Stuart Simpson
September 10, 2010 at 9:39 am[Joel Colthorpe] “Powermac G5 quad 2.5GHz”
That’s your problem right there. We have a similar spec machine and it’s slow with anything other than DV or DVCPRO. All the memory and drive space in the world isn’t gong to help you go any faster with such an old machine.
-Stuart Simpson
7 MacPros – Kona 3, Kona LH & Kona LHi
1 G5 – Kona LH
xbox360, Wii, PSP, PS3
https://www.speak.co.uk -
Rafael Amador
September 10, 2010 at 1:37 pmAn old machine: more reasons to make a good system cleaning. It won’t ever be a rocket, but sure will improve the performance.
Rafael -
John Fishback
September 10, 2010 at 9:27 pmIt is because of the drive loading. All drives start slowing down as you exceed 50% capacity. As you approach totally full it in effect slows down faster. That’s why your drive with 200GB left is faster than the one with 100GB left.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
