Activity Forums Adobe Premiere Pro Big Project Takes FOREVER To Load
  • Big Project Takes FOREVER To Load
    Posted by Kobi Versano on February 28, 2011 at 3:40 pm
    Hi everyone.
    I have a vert annoying problem with Premiere Pro CS5.
    I have this project that has roughly 2300 clips in it.
    Every time I load the project it takes a VERY long time to load (about 20 minutes)
    It goes through all the files each time and it’s very frustrating.
    Second, the software behaves in a very…choppy manner. When I drag a clip to the timeline, the motion is not smooth, playback takes a few seconds to start and the overall behavior is slow.
    The clips for this project are all in 720p MPEG 4 format.
    I use a Core i7, 4GB iMac 2.8Ghz.
    Please Help!
    Rob Orihuela replied 10 years, 9 months ago 4 Members · 3 Replies
  • Vince Becquiot
    February 28, 2011 at 6:36 pm
    Hi Kobi,
    When you are working with a good machine, this type of issue can usually be traced to drives.
    For this type of project, you’ll need a solid drive array that can pull a huge amount of data through. These days, I would recommend a RAID 10, all you have to do is look at ads on the Cow, most are good quality vendors.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Thuc Phan
    March 1, 2011 at 9:10 pm
    Use a separate hard drive for your cache and where the original files are stored.
  • Rob Orihuela
    July 29, 2015 at 1:36 pm
    are you saying keep the your cache and database on one external and then the project and source video files on another?
