Activity › Forums › Avid Media Composer › BIG problem with PLAY on adrenaline HD
  • BIG problem with PLAY on adrenaline HD
    Posted by German Rubio on November 22, 2005 at 12:41 pm
    Hi!!!
    Am working with adrenaline, and the secuence has offline video, not audio.
    I try to make play and this message appears:
    DECOMSTREAM: ALLOCATERANGE FRAME LENGHT <0
    I really have no clue what happens. I tried to make online the video with a batch capture 1:1 but also dont make it play.
    The only posibilitie its when i have no video stream selectionated.
    I tried to open a new project and consolidate it but it also doesnt work.
    The project its 27
    German Rubio replied 20 years, 10 months ago 2 Members · 5 Replies
  • R. Hewitt
    November 22, 2005 at 5:27 pm
    Have a check in the Console window and post the information here. It may provide more of an insight into the problem.
  • German Rubio
    November 22, 2005 at 6:02 pm
    I FORGOT TO HAVE A LOOK TO THE CONSOLE!!!!
    Ok. I
  • German Rubio
    November 23, 2005 at 9:38 am
    Hi again.
    The problem its a mistery.
    Yesterday my workmatte made the secuence Online, and today i was able to make play, and so on. Even when there is no effect rendered.
    I have problem with one effectt. The first stream its a freeze frame with color effect,the above stream ist a TGA secuence of 5 frames and then 1 second with another frame. And in the 3rd stream there is a filler with a glow effect. This effect i have used for 6 projects before but it fails till its not rendered.
    The message its:END OF FILE REACHED ON FILENAME and its the same message on console. Later when i render it there is no problem to make it play.
    Maybe i have to nest it?
    I also use this effect over a freezed stream without color effect and it works without render.
    Anybody knows what can be the problem? NESTING?
    Thanks to all
  • R. Hewitt
    November 23, 2005 at 11:34 am
    There is a reference in the Avid Knowledge base relating to this type of problem. One solution, although more drastic, is to delete the project settings.
    However, a more likely solution is:
    Set an IN point at the beginning of the timeline and an OUT point at the end of the sequence. Toggle your “Realtime Effects” button from the Green Dot to the Blue dot. Then go to your Clip menu and choose “Render IN/OUT”. Your sequence should play back fine now.
    Let us know if this solves the problem.
  • German Rubio
    November 25, 2005 at 7:55 am
    Hello again.
    I
