big problem with AE and FCP
ok guys another problem, need some help bad because something is very wrong, thanks in advance for the help, ok here we go
let me explain my workflow
the delivery has to be ntsc 29.97 in either a mpeg2 or mpeg4 file for the broadcast station, no tape just a digital file
my workflow is as follows, I shoot hvx200 at 720P 30PN at 30fps
I edit in fcp in hd as normal and then send those hd clips to ae cs3 as
a ref movie, in AE I create a new comp as regular ntsc dv D1 0.9 720×480 scale my HD clips to make sure they fit on a SD comp by “transform fit to comp width” and this creates the letterboxing effect
also, I make sure that on project settings my depth is set to 8 bits, working space is set to “none” and the “match legacy quicktime gamma adjust” is checkedok so I do as I normally do, do my graphics and text and all, when it comes time to render I render as dvcpro50 as highest quality, interlaced
now back in fcp I just export as mpeg4 or as mpeg2 using compressor, now somewhere along this adventure, something is wrong because it looks like crap, a lot of artefacts and the quality is just not there, please help me out and maybe someone can help me to see what I am doing wrong, thanks again guys
mike
