Activity Forums Apple Final Cut Pro Legacy Big problem in the Delta
  • Big problem in the Delta
    Posted by William Bearden on June 19, 2006 at 1:25 pm
    I moved my system (G5 Dual 2, FCP 5) from my city office to my home in the Miss. Delta for a little undisturbed editing, but I have a problem. My external drive (250 GB EIDE in a 2 bay removable drawer box) keeps going offline everytime I open FCP. After about a minute it disappears from the desktop and I get the “Device Removed without…” message. I’ve pulled some files from the drive over to another so I could begin editing, but every time I open FCP it goes offline. Without opening FCP, the drive shows up and I can play files through QT. I have about 3 hours of logged clips and can’t drag them onto my internal drive…it’s pretty full. Any help?
    William Bearden/Memphis
    Dean Sensui replied 20 years, 3 months ago 6 Members · 10 Replies
  • 10 Replies
  • Bouncing Account needs new email address
    June 19, 2006 at 1:26 pm
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • John Pale
    June 19, 2006 at 1:47 pm
    Are your drives daisy chained?
    How are you monitoring? (through a firewire device..camera, etc)?
    Sounds like somethings odd in your firewire bus.
    I dont think this is whats happening, but its a possilbility…The drive may be going to sleep…go into your Energy Saver preference pane and set your drives to never go to sleep.
  • William Bearden
    June 19, 2006 at 2:05 pm
    I’m going directly out of the Firewire bus to the removable box. I’m monitoring through a DSR 30 deck on the other bus. I am stumped.
  • William Bearden
    Thanks. I did that but it didn’t help.
  • Nick Meyers
    June 19, 2006 at 2:13 pm
    try swapping the buses and see what happens.
    nick
  • William Bearden
    June 19, 2006 at 2:27 pm
    Wow…I’m getting some strange digital breakup on the monitor now.
    Got the external drive back online but when I tried to reconnect the offline files the beach ball keeps spinning.
    June 19, 2006 at 2:33 pm
    You said it was an external drive…
    is it a FW external case for the drive?
  • William Bearden
    June 19, 2006 at 2:35 pm
    It’s a 2 bay Firewire box that has removable drawers that lock into place. It has two Firewire connections in the back. I have used this box for the past couple of months. Everything was cool till I moved it.
  • Mark Maness
    June 19, 2006 at 7:31 pm
    Maybe if you have enough room… try copying your data to an internal drive and reformat your external drives. Sometimes just moving the drives can get them a little out of sync. It’s very possible! If that doesn’t work, just try hooking your drives to the buss with your tape machine and leaving the tape machine unplugged. I know you won’t be able to monitor except for the FCP interface but its worth a shot to see if one of you firewire busses are have a problem.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Dean Sensui
    June 19, 2006 at 7:32 pm
    [william bearden] “It’s a 2 bay Firewire box that has removable drawers that lock into place. It has two Firewire connections in the back. I have used this box for the past couple of months. Everything was cool till I moved it.”
    Sounds like there might be some bad connections, either with the external cables and/or something inside the box. Moving it may have disturbed them. If possible, try re-seating all connectors and make sure they’re clean. Something called DeOxyIt from Caig might help.
    Dean Sensui — http://www.HawaiiGoesFishing.com
