Activity Forums Apple Final Cut Pro Legacy Bias Soundsoap
  • Posted by Nicholas Bierzonski on April 25, 2006 at 1:28 pm
    I have used Soundsoap many times in the past as a plug in in FCP. I always manually dial out the noise because if I use the learn noise function of Soapsoap it works but…when I play play the clip there is a delay of about 1 second before soundsoap kicks in. You can hear the room tone in all of it’s glory for about a second then Soundsoap kicks in and the noise disappears. Why does this happen? Does this happen to anyone else?
    I tried putting nodes on the audio for the first second of the clip that dropped the audio out. Soundsoap still waits a second after the first part of the clip with audio to kick in. Any ideas or suggestions?
    -Nicholas Bierzonski
    Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
    Nicholas Bierzonski replied 20 years, 5 months ago 3 Members · 5 Replies
  • Nicholas Bierzonski
    April 25, 2006 at 1:41 pm
    I forgot to mention that unlike when I use Soundsoap in Peak if I hit the learn noise button…the default parameters do not change. So also can’t tweak them and make adjustments.
  • Nate
    April 25, 2006 at 3:45 pm
    I have noticed the one second delay also. Sound Soap works great except for that delay. Sound Soap cleaned up the audio on old 3/4 tapes perfectly except at the very begining. You would think that there is a practical solution.
    April 25, 2006 at 8:10 pm
    Hmmmm… I wonder why that is. And also why isn’t there a visual version of Sound Soap in FCP? Don’t get me wrong. SoundSoap is great tool by why short change us important parts of the interface. And why the second delay before kicking in?
  • Matt Murray
    April 26, 2006 at 10:46 am
    Bias has a user forum here.
    https://www.bias-inc.com/support/userForums/
    You need to enter your serial number, but the feedback is usually quick and spot on.
    Matt Murray
    Lineside Productions
    Wellington, FL
    https://www.edgesportfishing.com
    Florida Sailfish videos, pictures and more
    Mac OS X 10.4.1 , QT 7.0 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD 5, DVDSP 4, Compressor 2.0, Motion 2.0
    Soundtrack Pro 1
    April 26, 2006 at 12:59 pm
    Thanks Matt!
