Activity Forums Lighting Design Bi colored versus daylight LEDs
  • Bi colored versus daylight LEDs
    Posted by Chris Pike on January 13, 2018 at 10:52 pm
    From my experience, I would argue that bicolored LEDs are not a good use of money. You are better of buying a daylight LED and throwing a CTO gel on it. What is your opinion?
    You will get more power with daylight LED + gel than with a bicolored LED adjusted to match.
    Also, I don’t like working with the knobs on the bicolored LEDs, they are difficult to properly adjust.
    Please discuss. Thanks.
    ps. I usually warm up the lights on my model, and have cooler (daylight) lights on my background. This why I like to have some warm lights.
    Leanne Lian replied 8 years, 7 months ago 3 Members · 2 Replies
  • Mark Whitney
    January 14, 2018 at 6:55 pm
    [chris pike] “From my experience, I would argue that bicolored LEDs are not a good use of money. You are better of buying a daylight LED and throwing a CTO gel on it. What is your opinion?
    You will get more power with daylight LED + gel than with a bicolored LED adjusted to match.”
    With incandescent & HMI lights, sure. With LED’s, no. A “warm” (i.e. 3200K) LED is manufactured to already be emmiting at that spectrum so you’re getting more output that way rather than “throwing away” light by gelling a 5500 LED source. The color temps in between are often just a blending of the two outputs.
    [chris pike]
    Also, I don’t like working with the knobs on the bicolored LEDs, they are difficult to properly adjust.”
    Pretty much agree there and that’s largely going to be up to the manufactures design.
  • Leanne Lian
    January 24, 2018 at 8:47 am
    budget is a question, but it also depended on the requirement, in which occasion installation, I think bi-color led light is mainly distinguish from RGBW
