Activity Forums Maxon Cinema 4D bhodiNUT = ??? in version10?
  • bhodiNUT = ??? in version10?
    Posted by Justin Rank on January 6, 2007 at 3:31 am
    In my continued education of C4D, I run into alot of tutorials to follow that don’t exactly translate well into version 10. In reading my manual, I’ve learned that bhodiNUT and SLA are now called shaders…but which ones?
    https://www.cinema4duser.com/tech_tutorial01.html
    Anybody care to translate some of the terms in the tutorial above into something a person who’s never used any other version than version10 can relate to?
    ugh…thanks in advance.
    Björn Marl replied 19 years, 8 months ago 3 Members · 2 Replies
  • Ingemar Björling
    January 6, 2007 at 8:11 am
    Just remove the name bhodinut, the shaders used in the tutorial are located at the same place as in previous version, i.e, bhodinut fresnel is still in the texture menu in the material chanels in the material editor, but renamed to fresnel.
    Renderwise Ingemar Bj
  • Björn Marl
    January 7, 2007 at 10:14 am
    Like Ingemar said, but be aware that the SLA version used in the tutorial is from R8.0. With 8.5 the shaders got completely reworked (thats why the names aren’t identical anymore) so you will see many changes in the interface and the parameters. Also many new shaders were included in 8.5. Most important check the new layer shader.
    Cheers
    Bj
