Activity › Forums › Boris FX › BFX API Error 817 Multiprocessor.cpp using Boris 4.3 and Edius 5.12
  • BFX API Error 817 Multiprocessor.cpp using Boris 4.3 and Edius 5.12
    Posted by Eddie Hanz on December 21, 2009 at 10:40 pm
    Whether trying to print to file, or burn to disc I am getting the error around 1/3 way through.
    The only Boris effect that I am using to this point is BCC- Brightness Contrast which is applied in a linear way over a 20minute segment (out of a 45 minute program).
    The segment itself is MPEG2 720×480.
    I am running Win 7 Ultimate x64, on a quad core Q8200 with 6GB of RAM and a 1.5TB Raid 0.
    I also noticed that Edius is sucking in a lot of RAM (2GB+) during the process, but this seems to drop to 100MB when I free up the memory using Windows 7 Manager. Any help/advice will be appreciated.
    Matt Mullen replied 16 years, 9 months ago 2 Members · 1 Reply
  • Matt Mullen
    December 22, 2009 at 2:36 pm
    Eddie,
    Are you running the latest update for Red on windows (4.3.3).
    If not download and install it from out updates page: https://www.borisfx.com/updates/
    If you are try trashing the Red preferences. To do so go to the C:/Windows folder and remove the BorisRed4.3.ini file.
    Does any of this resolve your issue?
    -Matt
