BFX API Error
Posted by N8tracks on August 30, 2005 at 6:28 amI’m getting “invalid menu handle menusImp.cpp” and then Red is no good after that.
can anyone help?
Fernando Borato replied 17 years, 2 months ago 4 Members · 4 Replies -
N8tracks
August 30, 2005 at 8:48 pmFYI if u get a crash with the text editor its a font conflict. thanks to BFX sales Dept. for acting as Tech Support.
N8
Jonathan Clegg
March 11, 2008 at 3:20 amIn the extensions folder there is a openGl plugin (boris) if this is deleted or removed from the folder these errors will not occur.
I have the same problem matey, this was the solution to get it to run.
Frank Sauer
March 31, 2009 at 12:27 pmHi Jonathan,
I get this error by draging a window in Red. Do you work on Mac? If not, where in windows is the extension folder, where i could find the open gl plugin to delete?greetings from Munich /Germany
Frank
Fernando Borato
July 4, 2009 at 1:48 amOlá,como resolver o problema do boris pinnacle,bfx api error lpane.cp 1897,presiso de sua ajuda Obrigado
Como resolver este erro no pinnacle boris,bfx api error lpane.cp 1897,me ajudem obrigado…
