Activity Forums Adobe After Effects Bezier curve in graphic editor acting weird. Can’t adjust angle only length of handle?
  • Bezier curve in graphic editor acting weird. Can’t adjust angle only length of handle?
    Posted by David French on August 17, 2016 at 1:26 am
    I’m trying to adjust the speed graph for my bezier curves and while I call pull the handle horizontally I can’t angle it up and down for some reason… anybody know what’s up?
    link to images
    David French replied 10 years ago 2 Members · 2 Replies
  • Walter Soyka
    August 17, 2016 at 2:58 am
    You’re editing the speed graph, which represents the rate of change of the property value, not the actual value itself. You might think of this as more of an indirect control. Change the graph view to value graph instead to get the traditional Bezier handles you’re looking for.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • David French
    August 17, 2016 at 5:40 pm
    Oh thank you, yes you’re right, that works now!
