Activity Forums Adobe After Effects Bezier Beam
  • Bezier Beam
    Posted by Hannes De on August 24, 2015 at 9:53 pm
    i’m stuck with a problem which i’m pretty sure should not be too tricky to solve but i just dont see it.
    i have 3 nulls, one tracked to footage, one with a wiggle expression on it and one in the middle which is connected to the others with the beam effect. now the client would like the beam to be curvy. i already found a thread which discusses exactly that problem:
    https://mograph.net/board/index.php?showtopic=27668
    somebody even posted the solution without explaining it (https://mylenium.de/_temp/nodes.mp4) must have to do sth with the obsolete path effect an some expressions but i don’t get it…
    help would be hoghly appreciated! thanks in advance!
    cheers,
    hannes
    Hannes De replied 11 years ago 4 Members · 4 Replies
  • Walter Soyka
    August 25, 2015 at 12:18 am
    Path Text is still there in the Obsolete category. Use a bunch of periods/full stops/baseline dots as the text, tighten the tracking so the characters smush together, and manipulate the control points (with or without expressions).
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Cassius Marques
    August 25, 2015 at 5:46 pm
    This Link would also solve your problem…its a purchasable script. You could link your 2 beam nulls to a mask and your third null to the script’s mask handles giving it a bezier curve.
  • Kalleheikki Kannisto
    August 25, 2015 at 7:19 pm
    And one more option: Draw a beam and use the puppet tool at two ends and middle, attached to your nulls.
  • Hannes De
    September 3, 2015 at 1:52 pm
    Problem has been solved with the puppet tool. Thx guys! 🙂
