Activity Forums Avid Media Composer bewildered fcp editor trying to bathc export ales
  • bewildered fcp editor trying to bathc export ales
    Posted by Sam Woolf on January 22, 2009 at 2:39 pm
    Hi there,
    I’m a fcp editor and don’t really know my way around avid – however I’ve been asked to essentially convert an avid project to a fcp project.. and my client doesn’t want to buy automatic duck – my time being considerably cheaper 🙁
    Anyway – I’ve found a tool that is able to import ale files into fcp and retain most of the useful info – but I can’t find a way of batch exporting all the bins in the avid project as ale files – as there are hundreds of bins in the project it would take forever to do one by one and I’m sure there must be a quicker way –
    would be very grateful if someone could give me a prod in the right direction..
    Sam.
    Rob Alexander replied 17 years, 8 months ago 3 Members · 2 Replies
  • Michael Phillips
    January 22, 2009 at 8:05 pm
    There is no way to batch import from all bins at once. Were these clips created from an import file to start with? If so, you can always use those. And Automatic Duck would not work in this case either since it is based on sequences and you are doing all your source clips.
    Michael
    Michael Phillips
  • Rob Alexander
    January 26, 2009 at 9:50 pm
    you could use the media tool to find all the clips in your project then create a new bin and copy all from the media tool to that bin.
