Activity › Forums › Adobe After Effects › Bevel Transparency Question – WITH PICTURES
  • Cassius Marques
    February 7, 2020 at 11:32 am
    That is exactly what the screen blend mode is supposed to do, remove blacks. If you think it should look different perhaps remove black using an effect (UnMult) and adjust the alpha with a curve.
    Cassius Marques
    http://www.zapfilmes.com
  • Bradley Kus
    February 7, 2020 at 10:49 pm
    Ahh gotcha! I never actually knew the technicalities behind what the Screen mode was actually doing, but yes that makes sense. Thanks for the explanation, and the tip! Appreciate it.
  • Bradley Kus
    February 11, 2020 at 1:32 am
    That UnMult method actually worked great! Just tried it – thanks Cassius!
