Activity Forums Maxon Cinema 4D Bevel a boolean?
  • Bevel a boolean?
    Posted by Brad on June 23, 2005 at 12:25 am
    I have a primitive object like a sphere with a cube booleaned out of the center. So basically its a sphere with a square hole going all the way through it. Is there any way to bevel the edges of that boolean so that the sqaure hole doesn’t have sharp edges? I appreciate any help.
    -Brad
    Brian Jones replied 21 years, 2 months ago 2 Members · 1 Reply
  • Brian Jones
    June 23, 2005 at 3:46 am
    You need to make the boolean editable or do a Current State to Object. Select the edges you want to bevel and use the bevel tool. Results are going to be varied depending on how the cuts go through the sphere. It’s really hard to get it to look good with some geometries…
