Activity Forums Adobe After Effects Better youtube format
  • Better youtube format
    Posted by Lumpynifkin on March 19, 2007 at 11:34 pm
    i just uploaded a video to youtube, when on my comp it looks great but when looking at it on youtube it looks much worse. I see other videos on youtube that have much better resolution and quality. What file format, quality, frame rate makes the best flash video uploads.
    Will
    I don’t know if this is basic or regular question so i am posting on both fourums
    thanks for any help
    Bernat Aragones replied 16 years, 4 months ago 3 Members · 2 Replies
  • Brett Sanders
    March 22, 2007 at 4:49 pm
    Encode it to a Xvid/Divx mp3 video at 320×240. Youtubes encoding systems run on the same type of Mpeg-4 video. This will give you the best quality.
  • Bernat Aragones
    May 20, 2010 at 9:28 pm
    Quick Time uses .mov and I believe .mov is the extension for HD. If you’re looking to export in any format I’d suggest you use Quick Times .mov. If the file is to large you might try reducing the quality a bit by lowering the frame rate or color variation. By color variation I mean change the preset unlimited depth from “millions of colors” to “256”. You’ll find the color depth output module which should be an available selection before you render the video.
    -Mr. Deneuralyzer-
    https://myspace.com/Deneuralyzer
