Activity Forums VEGAS Pro Better subtitle solution for Vegas
  • Better subtitle solution for Vegas
    Posted by Paulo Viana on April 27, 2007 at 5:23 pm
    I need to subtitle four 20 min video every month (and print to video). Today I manually do it (copy/paste on the text and create every text file on Vegas). Is there a better way for this? Or a plugin or a script? Thanks.
    Ron Shook replied 19 years, 4 months ago 6 Members · 9 Replies
  • 9 Replies
  • Gary Kleiner
    April 27, 2007 at 8:29 pm
    Create a .txt file.
    Each line will create a new subtitle when you use the Import Subtitles button.
    Then, you just have to tweak their positions to match the video.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Paulo Viana
    April 27, 2007 at 9:08 pm
    Gary,
    When do you say “Import subtitles”, where I can find it? Are you talking about Architect or Vegas? Is it an script for Vegas? I need to subtitle for print to tape, not for DVD. To do this I need to create several Text Medias, is it correct? This is my problem.
    Thanks for your help.
    Paulo
  • Gary Kleiner
    April 27, 2007 at 9:49 pm
    Oops, I was thinking this was for DVD.
    I think you’ll just have to place your text events, then copy and paste into them.
    Gary Kleiner
  • Adam Rose esq.
    April 27, 2007 at 11:59 pm
    google the following terms: subtext vegas script freeware
    you should find something
  • Charles Avanti
    April 28, 2007 at 1:06 am
    If I’m not mistaken, Ed Troxel made a script to do that, but I don’t recall the name. Hew made it for me a few years ago, then I think he was going to put it into excalibur.
    Charlie
  • Edward Troxel
    April 29, 2007 at 2:30 am
    It all depends on exactly what you’re wanting to do. If you’re creating a series of text events, a script can’t help you change the text. I do have the “Quick Labels” tool in Excalibur but I’m still unclear exactly what you’re trying to do.
    Edward Troxel
    JETDV Scripts
  • Paulo Viana
    April 30, 2007 at 3:57 pm
    Edward,
    I looked at Excalibur webpage and I read that Excalibur Quicklabel can get regions to be used to create titles. Can I use the regions’ text to create this subtitles?
    If it’s correct, I could use a script to create several regions from a .txt file (each line a separate region) than I run Excalibur Quicklabel to create subtitles. Is it possible?
    Paulo
  • Edward Troxel
    April 30, 2007 at 5:08 pm
    Yes, that is possible. You would use a script to set the regions and then Excalibur can create the text from those regions. NOTE: The “text” is actually a PICTURE/Image created by Excalibur.
    Edward Troxel
    JETDV Scripts
  • Ron Shook
    May 3, 2007 at 6:11 pm
    Paulo,
    [Paulo Viana] “I need to subtitle four 20 min video every month (and print to video). Today I manually do it (copy/paste on the text and create every text file on Vegas). Is there a better way for this? Or a plugin or a script? Thanks.”
    You might want to look into this Photoshop CS plugin if you have a version of PS CS (PS version 8 or higher.) It looks like it may do what you want. It adds a TV specific pallete to PS with batch processing:
    https://www.toolsfortelevision.com/pro
    You can download a trial and they’re running a special with a new version intro for $129 (regular $179.) I don’t know when the special ends. I haven’t used this and am in no position to do so right now, but would appreciate a report if anyone wants to give it a try.
    Ron Shook
