Activity Forums Adobe After Effects Better Stroke Reveal than Stroke?
  • Better Stroke Reveal than Stroke?
    Posted by Matthew Rogers on August 20, 2011 at 3:34 am
    Hey gang, I am trying to do a stroke reveal on a graphic from photoshop in AE 5.5. Before, I’ve always been able to do it easily in AE, I am guessing because the 50 pixel brush is big enough. The fancy text I am trying to reveal won’t come close to fitting in the 50 pixel brush, so I am looking for another, smoother way to stroke on (in reality, reveal) the image. I tried doing the multiple masks with stroke all masks, but that causes little dips between the brushes. Is there not any way to follow a single mask shape and get something bigger than 50 pixels?
    Matthew
    Mato Kokotic replied 15 years ago 3 Members · 2 Replies
  • Ben G unguren
    August 20, 2011 at 7:25 pm
    If you wanted you could scale up your layer, match up your paths, and then you’d have a thicker stroke. Of course it will be a bit blurry as it gets scaled up….
    You could also try using the paintbrush (make sure you’ve set things so the stroke “draws itself in”). You’d have to use the paintbrush as a matte for the graphic lines being drawn in…
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mato Kokotic
    August 20, 2011 at 9:08 pm
    You can use animated Stroke on different layer, apply negative Matte Choker (more itterations if needed) and use that layer as Alpha Matte for your text layer.
