Activity Forums VEGAS Pro Better slowmo with de-interlacing
  • Better slowmo with de-interlacing
    Posted by Anders Fougner on May 22, 2009 at 11:36 am
    Hi!
    I have been reading a bit about using deinterlacing to get a better slowmo… But now i understand that if i deinterlace for example some 60i footage, all I get is something close to 30p, and then i might just aswell shoot in 30p, right? I found this method on how to go from 60i to 60p, but it’s just to much work for me with the type of videos I’m makin: https://eugenia.gnomefiles.org/2009/02/09/butter-smooth-slow-motion/
    Is there another way to go from 60i to 60p in sony vegas?
    Thanks;
    Anders
    Todd Geer replied 15 years, 2 months ago 3 Members · 3 Replies
  • D. Eric franks
    May 22, 2009 at 5:51 pm
    If you change the velocity of a clip in Vegas to 50% you get exactly what you need. The end.
    Specifically: toss a 29.97fps 60i clip into a 29.97fps 60i project, right click the clip > Properties and change the Playback rate to 0.500. Now change the Preview window to Best (Full) to make sure you are seeing your actual output frames and hop through the project frame-by-frame. You should see a change in every single frame, confirming that you are now getting 60fps. Sweet.
    ___________
    Film will only became an art when its materials are as inexpensive as pencil and paper.
    — Jean Cocteau —
    https://videopia.org
  • Anders Fougner
    May 24, 2009 at 12:02 pm
    Nope, this doesn’t work… I still get the ugly interlace flicker thing..
  • Todd Geer
    July 5, 2011 at 1:51 pm
    Quick note. This helped me; thanks for the info.
