Activity Forums Apple Final Cut Pro Legacy Better quality at 1080 or 720p?
  • Better quality at 1080 or 720p?
    Posted by Piff Aroni on December 23, 2009 at 2:29 am
    I have a canon hf10, which records in 1920 x 1080. Most of my work will be placed on SD DVD, youtube, and the web. My question is with the workflow and the final quality.
    would I get better quality if I recored at 1920 x 1080 and then IMPORTED the footage into final cut AT FULL HD QUALITY (1080) and edit in FCP at 1080 and then EXPORT to a 720p (via compressor) setting for youtube OR would I get better quality in changing the SEQUENCE PRESET to a 720p setting in FCP and work with it as 720?
    Ernie Santella replied 16 years, 4 months ago 3 Members · 2 Replies
  • Rafael Amador
    December 23, 2009 at 2:51 am
    Hi Piff,
    FC can do a nice downscaling.
    Set “Render in High Precision” and “Render Motion Effects: BEST”.
    Rafael
    http://www.nagavideo.com
  • Ernie Santella
    December 23, 2009 at 3:04 pm
    Edit in HD an then downrez to SD. This gives you a master in HD for later use, plus, it looks so much better to show a client your project in HD.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
