Activity Forums Apple Final Cut Pro Legacy Better program than Google Earth?
  • Better program than Google Earth?
    Posted by Bernard Ageeb on February 26, 2008 at 4:31 pm
    Hi, I’m working on a project where I want t use the Google Earth effect of looking at the Earth and showing a from space view but want more control and better image quality so that i can put it in my Final Cut project and make it look real.
    Thanks for the help
    bernard
    Aaron Stewart replied 18 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    February 26, 2008 at 4:35 pm
    If you purchase the Pro or Enterprise versions, you get much higher quality images and animations.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Shane Ross
    February 26, 2008 at 6:42 pm
    Well, if you have $10-$15 thousand dollars, there is always Curious World Maps. I use that myself.
    https://www.curious-software.com/products/worldmaps/
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Aaron Stewart
    February 27, 2008 at 4:37 am
    If you have Adobe After Effects you could download a Nasa Blue Marble image from Nasa’s site (below), use CC Sphere and have fun with that.
    -Aaron R. Stewart
    https://www.nasa.gov/vision/earth/features/blue_marble.html
    I would suggest a summer image, probably not the largest .tiff file, but the largest .jpg one might do nicely, depending of course on how close you want to get to the earth. If you want to get closer to the earth, then either of the aforementioned programs should work nicely.
  • Bernard Ageeb
    February 27, 2008 at 2:42 pm
    Hi Aaron, i down loaded the earth image. But when i put it on my timeline in After effects a message comes up saying After effects error: could not create 21600 x 10800 image buffer. How can i fix this? Thanks in advance
    Bernard
  • Aaron Stewart
    February 27, 2008 at 4:00 pm
    Heh, yes I’ve gotten that very same message. I usually scale the image down to a more manageable size in photoshop, then import into AE. You can probably scale down by 50% or so, and still get good results.
    Are you doing SD or HD?
  • Bernard Ageeb
    February 27, 2008 at 6:50 pm
    I am using HD
  • Aaron Stewart
    February 27, 2008 at 7:15 pm
    Then just open a blank 720 or 1080 template in PS, copy-paste the whole image in, resize manually until you get to the absolute maximum closest possible point you want to be to the earth. Apply the transformations to the layer, then copy, create new document (shows dimensions of what you just copied) and paste into the new document, then use that in AE to apply CC Sphere to. I assume you can do this anyways, just making sure. 🙂
    The HD renders will be pretty slow, depending on your system. Don’t forget clouds (there are also Nasa cloud images of the earth you can pull from). You can either make them a separate CC Sphere comp on top of your original if you want them to move independantly (more render time) OR just marry them to the PS image.
    Aaron
