Activity › Forums › Adobe Premiere Pro › Better morph cut than morph cut?
  • Better morph cut than morph cut?
    Posted by Peter Wu on May 27, 2022 at 7:10 pm
    I tried to use the morph cut transition in premiere pro to fix speech problems in interviews. E.g. coughing, excessive use of “er”, or stuttering. Basically I would do a jump cut to delete the unwanted sound, then use a morph transition to hide the jump cut. It works kind of, except it produces “lazy mouth” that does not move and does not lip sync.
    I know other video editors also have similar morph transition feature. Are they all like this or is there one that lip syncs much better than premiere pro?
    Peter Wu replied 4 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
