Activity Forums Apple Final Cut Pro Legacy Better looking conversion… 30p>24p or 25p>24p
  • Better looking conversion… 30p>24p or 25p>24p
    Posted by Cade Muhlig on January 5, 2012 at 1:13 am
    I got a small contour action cam thing recently, and I want to use it to spice things up and get some different angles on our next documentary.
    The other cameras shoot in 24p, which is what I edit and master in, but it will eventually go to broadcast (NTSC).
    I have only two choices of frame rates with the little camera: 25p and 30p. What’s going to make a better looking conversion to 24p? I tested and discovered that 25p is better in low light, so that’s a plus. What do you say?
    Cade Muhlig replied 14 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    January 5, 2012 at 1:53 am
    25p, if you don’t need to worry about sync sound. Convert to ProREs…then Conform with Cinema Tools to 24fps…done.
    Shane
    Little Frog Post
  • Cade Muhlig
    January 5, 2012 at 1:59 am
    basically that would speed up the audio/video using cinema tools right?
    Have sync sound I think will be needed. Converting to prores, then right into final cut pro would mean final cut will drop one frame a second though right? Would it look bad? Then I wouldn’t have to worry about having the time go out of sync. or am I missing something?
  • Shane Ross
    January 5, 2012 at 8:23 am
    If you need to keep things in sync, then 30fps to 24fps would be the better option. Conforming 25 to 24 would throw things off.
    Shane
    Little Frog Post
  • John Heagy
    January 6, 2012 at 12:52 am
    [Shane Ross] “If you need to keep things in sync, then 30fps to 24fps would be the better option. Conforming 25 to 24 would throw things off.”
    I would suggest the opposite. 25 to 24 is such a slight slow down that you can do the same to the audio and not notice the pitch change. I can recommend Episode 6 for this but Compressor may do it as well.
    John
  • Cade Muhlig
    January 7, 2012 at 11:24 pm
    Yes, but any amount of slowing will make it lose sync with audio recorded on a different device.
    Thank you both though.
    It’s going to be daylight for all the shots i think, so 30p will be fine. and the extra frames will allow me to slow it down a bit in post if needed.
