Activity Forums Apple Final Cut Pro Legacy Better FCP 7 SmoothCam plug in
  • Better FCP 7 SmoothCam plug in
    Posted by Enrico Lappano on March 26, 2013 at 3:02 pm
    Can someone recommend a better smoothcam plug-in solution than the one that is included with FCP 7? Unless I’m not using it properly, (primarily with 7D clips and sometimes HDV), it leaves noticeable “jello” jitter and cropping. I was told that Premier has a good plug in for this, as well as FCP X.
    I’d really appreciate any feedback.
    Enrico Lappano replied 13 years, 6 months ago 3 Members · 4 Replies
  • Enrico Lappano
    March 26, 2013 at 4:12 pm
    Thanks Dave. Can I use that, or is there a plug-in available that’s as effective as the “Warp Stabilizer, with a Rolling Shutter feature” available for FCP 7, which I am editing on? My footage has been transcoded to ProRes 422.
  • Steve Eisen
    March 26, 2013 at 5:55 pm
    Lock and Load from CoreMelt
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Anna Ingenthron
    March 26, 2013 at 9:37 pm
    Importing the shot into Apple Motion (in the FCP suite) as a project and adding the behavior “Stabilize” under Motion Tracking. Smooths things out nicely if you don’t mind the little export and import.
  • Enrico Lappano
    March 26, 2013 at 10:16 pm
    Between the three options for FCP 7 for best smoothcam is it safe to say first that the FCP 7 smoothcam plug-in is not even an option (at least from my experience, but I haven’t compared it with anything) ?
    But between the other two, ultimately, I’m after the “smoothest” option. Will $100 for Lock and Load X bring best results or extra time importing into Apple Motion?
    I appreciate all your feedback, cause the effect can make a dramatic difference.
