Activity Forums Apple Final Cut Pro Legacy Better Dissolves
  • Better Dissolves
    Posted by Scott Davis on August 19, 2010 at 5:18 pm
    There used to be a plug in by Buena Software called “Dissolve Factory”. It doesn’t seem to be around anymore. Does anyone know of a better dissolve than the stock ones in FCP. I hate the way they “pop” on.
    Scott Davis
    View Scott Davis's profile on LinkedIn
    Rafael Amador replied 16 years ago 7 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    August 19, 2010 at 5:23 pm
    https://www.nattress.com I believe that FILM EFFECTS has a FILM DISSOLVE. The site has demo versions for download.
    Never had an issue with the dissolves. they “pop on?”
    Shane
  • Scott Davis
    August 19, 2010 at 5:31 pm
    When a cross dissolve is applied to a pict file (title I made in PS) I want the dissolve to be slower. Longer dissolve doesnt seem to work. Its seems like the graphic goes from 0% opacity to at least 80-100% in the first half of the dissolve.
    Scott Davis
  • Pradip Patil
    August 19, 2010 at 5:37 pm
    Have you tried changing the start or end values of the FCP dissolves?
  • Scott Davis
    August 19, 2010 at 5:41 pm
    D’oh!! Forgot about that. I will play with it.
    Scott Davis
  • John Knapich
    August 19, 2010 at 5:51 pm
    You can also use key frames in the clip overlay to customize a dissolve rate.
    FCP 6.06, OS 10.5.8 2x3GHZ Quad-Core Intel Xeon, Kona LHe, Dulce Duo-eSATA 8 Drive, 4TB Raid.
    John Knapich
    Creative Director/Partner
    Assembypix.tv
  • John Fishback
    August 19, 2010 at 7:05 pm
    https://www.coremelt.com/ has many different dissolves.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Mark Petereit
    August 19, 2010 at 9:53 pm
    I have also found that keyframing the luminance from 100 to 0% (or vice versa) gives a much more “film-like” dissolve if that’s what you’re looking for.
  • Rafael Amador
    August 20, 2010 at 2:37 am
    The Buena Dissove factory disappear long ago. These dissolves where Film-like.
    For normal dissolve (?) you can use the Nattress, BUT FROM the “Nattress Big Box of Tricks” (G Dissolve, Long Dissolve).
    The dissolves from the Nattress Film Effects there are also just for film look.
    Rafael
    http://www.nagavideo.com
